Saltar al contenido principal
How to Open the Rotor Riot
Qué necesitas
  1. How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 1 de 3 How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 2 de 3 How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 3 de 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. How to Open the Rotor Riot, Unscrew the back cover: paso 2, imagen 1 de 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 1 de 3 How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 2 de 3 How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 3 de 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 1 de 3 How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 2 de 3 How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 3 de 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. How to Open the Rotor Riot, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
Conclusión
Adriana Zwink
Miembro Desde 12/18/19
40,177 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
140 Miembros
17,590 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 131
