Saltar al contenido principal
Introducción
Use this guide to open the Rotor Riot controller for repairs and modding.
Partes
No se especificaron partes.
  1. How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 1 de 3 How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 2 de 3 How to Open the Rotor Riot, Remove the iPhone mount: paso 1, imagen 3 de 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. How to Open the Rotor Riot, Unscrew the back cover: paso 2, imagen 1 de 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 1 de 3 How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 2 de 3 How to Open the Rotor Riot, Swing open the back cover: paso 3, imagen 3 de 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 1 de 3 How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 2 de 3 How to Open the Rotor Riot, Disconnect the phone connector cable: paso 4, imagen 3 de 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. How to Open the Rotor Riot, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
Conclusión
Adriana Zwink
Miembro Desde 18/12/19
34,889 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
146 Miembros
16,069 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 61
