Saltar al contenido principal
Introducción
Use this guide to open the left controller handle of your Backbone One for repairs and modding.
  1. How to Open the Left Handle of the Backbone One, Unfasten the screws: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. How to Open the Left Handle of the Backbone One, Rotate the upper cover: paso 2, imagen 1 de 3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: paso 2, imagen 2 de 3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: paso 2, imagen 3 de 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. How to Open the Left Handle of the Backbone One, Remove the protective tape: paso 3, imagen 1 de 3 How to Open the Left Handle of the Backbone One, Remove the protective tape: paso 3, imagen 2 de 3 How to Open the Left Handle of the Backbone One, Remove the protective tape: paso 3, imagen 3 de 3
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. How to Open the Left Handle of the Backbone One, Open the ZIF connector: paso 4, imagen 1 de 2 How to Open the Left Handle of the Backbone One, Open the ZIF connector: paso 4, imagen 2 de 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: paso 5, imagen 1 de 2 How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: paso 5, imagen 2 de 2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. How to Open the Left Handle of the Backbone One: paso 6, imagen 1 de 2 How to Open the Left Handle of the Backbone One: paso 6, imagen 2 de 2
    • Remove the upper half of the left controller assembly.
Conclusión
Opening didn’t go as planned? Answers community for help.
Adriana Zwink
Miembro Desde 18/12/19
34,949 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
145 Miembros
16,174 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 301
