Saltar al contenido principal
How to Open Logitech Harmony 1100
Qué necesitas
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: paso 1, imagen 1 de 2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: paso 1, imagen 2 de 2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. How to Open Logitech Harmony 1100: paso 2, imagen 1 de 1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: paso 3, imagen 1 de 2 How to Open Logitech Harmony 1100: paso 3, imagen 2 de 2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. How to Open Logitech Harmony 1100: paso 4, imagen 1 de 3 How to Open Logitech Harmony 1100: paso 4, imagen 2 de 3 How to Open Logitech Harmony 1100: paso 4, imagen 3 de 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
Conclusión
Una persona más ha completado esta guía.
Keegan Williams
Miembro Desde 02/19/16
216 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-5, Garvin Spring 2016 Miembro de Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Miembros
3 Guías creadas
Un comentario
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,387
