Saltar al contenido principal
How to Mend a Hole in a Knit Blanket
Qué necesitas
  1. How to Mend a Hole in a Knit Blanket, How to Mend a Hole in a Knit Blanket: paso 1, imagen 1 de 1
    • Thread the wool needle by inserting the yarn through the needle's eye.
    • Tie a knot at the end of the yarn that faces away from the needle's point. You'll leave the other end of the yarn alone and it will hang freely. That is ok!
    • Insert the needle in the back of the blanket and pull until the knot stops you from pulling further.
    • You will be making zig-zag stitches.
  2. How to Mend a Hole in a Knit Blanket: paso 2, imagen 1 de 3 How to Mend a Hole in a Knit Blanket: paso 2, imagen 2 de 3 How to Mend a Hole in a Knit Blanket: paso 2, imagen 3 de 3
    • Insert the needle diagonally in the front of the blanket and grab the needle from the back.
    • Tightly pull the thread through.
    • Insert the needle diagonally again but this time from the back.
    • Repeat the zig-zag motion until you reach the top of the hole.
  3. How to Mend a Hole in a Knit Blanket: paso 3, imagen 1 de 3 How to Mend a Hole in a Knit Blanket: paso 3, imagen 2 de 3 How to Mend a Hole in a Knit Blanket: paso 3, imagen 3 de 3
    • Once you reach the top of the hole, insert the needle through the front of the blanket and pull from the back.
    • Turn the blanket over so you see the back of the stitches.
  4. How to Mend a Hole in a Knit Blanket: paso 4, imagen 1 de 2 How to Mend a Hole in a Knit Blanket: paso 4, imagen 2 de 2
    • To make a knot to secure the yarn, insert the needle through any stitch to create a loop.
    • Once you have a loop, insert the needle through the loop and pull until you have a knot. Repeat one more time.
    • Cut the remaining yarn close to the knot (but not too close), and now your hole is closed and secure.
Conclusión
Repair a hole in a knit blanket using zig-zag stitches using a wool needle and yarn.
Rebecca King
Miembro Desde 10/15/22
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 136
Todo El Tiempo: 2,593
