Introducción
Use this guide to lubricate a rusted measuring tape.
Over time, measuring tapes can get rusty, making it hard to operate the measuring tape properly. This guide will show you six simple steps to lubricate your tape measure, helping it work like new again.
Qué necesitas
Loosen and remove the 9.5 mm screw using a Phillips #1 screwdriver.
Remove the belt clip.
To put your measuring tape back together, follow these steps in reverse order. Make sure all parts are secure before snapping the case shut and screws are hand tightened. Once put back together, test the measuring tape by pulling the tape out and allowing it to retract.
