Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Lengthen a Necklace Chain
Qué necesitas
    1. How to Lengthen a Necklace Chain, How to Lengthen a Necklace Chain: paso 1, imagen 1 de 1
      • Measure and determine the desired length of jewelry chain that you want to add.
      • Place a piece of tape to mark where you want to cut.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Lengthen a Necklace Chain: paso 2, imagen 1 de 1
      • Cut the extender chain with wire cutters/scissors at the tape marker.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Lengthen a Necklace Chain: paso 3, imagen 1 de 1
      • Look at your jump ring. If there is no opening in the jump ring, carefully cut the ring yourself with scissors.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Lengthen a Necklace Chain: paso 4, imagen 1 de 1
      • Use jewelry pliers to open the jump ring at one end of the extender chain and one end of the jewelry chain.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Lengthen a Necklace Chain: paso 5, imagen 1 de 1
      • Connect one end of the extender chain to the jump rings.
      • Repeat the process by attaching one end of the jewelry chain to the same jump ring the extender chain is on.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Lengthen a Necklace Chain: paso 6, imagen 1 de 1
      • With the jewelry pliers, carefully squeeze the jump ring shut, ensuring both the extender chain and jewelry chain remain securely attached to it.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Lengthen a Necklace Chain: paso 7, imagen 1 de 1
      • Make sure that the extender chain's closure is secure and won’t open or come loose during wear. If everything seems correct, you are ready to wear it!
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Faith Low
Miembro Desde 04/26/24
145 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-3, Whithaus Spring 2024 Miembro de UC Davis, Team 2-3, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G3
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 51
Todo El Tiempo: 626
