Saltar al contenido principal
How to Install an HID Conversion Kit
Qué necesitas
  1. How to Install an HID Conversion Kit, Headlights: paso 1, imagen 1 de 2 How to Install an HID Conversion Kit, Headlights: paso 1, imagen 2 de 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: paso 2, imagen 1 de 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: paso 3, imagen 1 de 2 How to Install an HID Conversion Kit: paso 3, imagen 2 de 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: paso 4, imagen 1 de 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: paso 5, imagen 1 de 2 How to Install an HID Conversion Kit: paso 5, imagen 2 de 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: paso 6, imagen 1 de 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: paso 7, imagen 1 de 3 How to Install an HID Conversion Kit: paso 7, imagen 2 de 3 How to Install an HID Conversion Kit: paso 7, imagen 3 de 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Conclusión
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
6 personas más completaron esta guía.
Eric Wu
Miembro Desde 01/21/15
3,357 Reputación
23 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 119
Todo El Tiempo: 16,298
