Saltar al contenido principal
How to Install a Fifth String Shubb Banjo Capo
Qué necesitas
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: paso 1, imagen 1 de 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: paso 1, imagen 2 de 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: paso 1, imagen 3 de 3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: paso 2, imagen 1 de 1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: paso 3, imagen 1 de 1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: paso 4, imagen 1 de 2 How to Install a Fifth String Shubb Banjo Capo: paso 4, imagen 2 de 2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: paso 5, imagen 1 de 3 How to Install a Fifth String Shubb Banjo Capo: paso 5, imagen 2 de 3 How to Install a Fifth String Shubb Banjo Capo: paso 5, imagen 3 de 3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Conclusión
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 personas más completaron esta guía.
Sara Wier
Miembro Desde 02/24/15
263 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 23-4, Green Winter 2015 Miembro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 57
Todo El Tiempo: 6,882
