Saltar al contenido principal
How to Hem a Dress
Qué necesitas
  1. How to Hem a Dress, How to Hem a Dress: paso 1, imagen 1 de 2 How to Hem a Dress, How to Hem a Dress: paso 1, imagen 2 de 2
    • Begin with dress that is too long for the desired fit or style.
  2. How to Hem a Dress: paso 2, imagen 1 de 1
    • Lay the dress out flat, aligning the bottom seams.
    • Make sure any under layers are out of the way.
  3. How to Hem a Dress: paso 3, imagen 1 de 1
    • With a ruler, measure the amount you want the dress shortened.
    • After deciding, subtract 1" (25.4mm) from the seam allowance
    • (Ex: You want 3" (76.2mm) off, so you would measure 2'' (50.8mm) from the bottom of the fabric.)
  4. How to Hem a Dress: paso 4, imagen 1 de 1
    • Use chalk or pen to mark the measurement.
    • Make small dashed marks around the entire dress to ensure a consistent measurement.
  5. How to Hem a Dress: paso 5, imagen 1 de 1
    • Iron the dress flat.
  6. How to Hem a Dress: paso 6, imagen 1 de 1
    • Use scissors to cut vertically from the bottom seam to where you marked your measurement.
  7. How to Hem a Dress: paso 7, imagen 1 de 1
    • Then turn the scissors 90 degrees and begin cutting along the dashed lines you made in Step 4.
  8. How to Hem a Dress: paso 8, imagen 1 de 1
    • Then, again with the ruler and chalk measure 1/2'' (12.7 mm) from the raw edge of the fabric.
  9. How to Hem a Dress: paso 9, imagen 1 de 2 How to Hem a Dress: paso 9, imagen 2 de 2
    • Fold along the measurement you just made and iron it flat.
  10. How to Hem a Dress: paso 10, imagen 1 de 2 How to Hem a Dress: paso 10, imagen 2 de 2
    • Then fold again, one more time at 1/2''.
    • Lastly iron flat.
  11. How to Hem a Dress: paso 11, imagen 1 de 2 How to Hem a Dress: paso 11, imagen 2 de 2
    • Pin the fold in place.
    • Be careful when you pin.
  12. How to Hem a Dress: paso 12, imagen 1 de 1
    • If using a sewing machine, place it under the foot of the sewing machine.
    • Sew around the entire circumference of the dress.
    • Be careful when using a sewing machine.
  13. How to Hem a Dress: paso 13, imagen 1 de 3 How to Hem a Dress: paso 13, imagen 2 de 3 How to Hem a Dress: paso 13, imagen 3 de 3
    • Cut the threads and you're done!
Conclusión
Juliette Price
Miembro Desde 02/02/24
217 Reputación
1 Guía escrita
Equipo
UC Davis, Team 3-5, Andersen Winter 2024 Miembro de UC Davis, Team 3-5, Andersen Winter 2024
UCD-ANDERSEN-W24S3G5
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 93
