Saltar al contenido principal
How to Glue a Broken High Heel
Qué necesitas
  1. How to Glue a Broken High Heel, How to Glue a Broken High Heel: paso 1, imagen 1 de 1
    • Locate a high heeled shoe that has its heel partly or completely removed from its base.
    • Remove loose dirt , surface soil, and debris from the heel and sole of the shoe using a dry, soft-bristled shoe brush or damp paper towel.
    • Blot the fabric with a dry paper towel and allow the shoes to air dry away from direct heat and sunlight.
  2. How to Glue a Broken High Heel: paso 2, imagen 1 de 1
    • Use sandpaper to repair structural damage and roughen the material to make it easier for glue to bond. Lightly rub the heel and sole of the show in small, concentric motions until the surface is completely leveled and smooth.
    • Apply a generous coating of superglue on both the heel and the sole of the shoe so that a thick layer of glue forms between the sole and heel layers.
    • Caution: Heavy-duty super glue can cause skin irritation and may produce an allergic reaction if exposed to in high levels.
  3. How to Glue a Broken High Heel: paso 3, imagen 1 de 1
    • Using your hands, use substantial pressure to press the heel and shoe together to enforce the bond for 10-15 minutes.
  4. How to Glue a Broken High Heel: paso 4, imagen 1 de 1
    • Secure the heel in place with either rubber bands or a heavy object for at least 24 hours.
Conclusión
Tibirni Yusuf
Miembro Desde 09/28/22
121 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 60
Todo El Tiempo: 1,306
