Introducción
The following guide will help you to fix the CHP Mode Switch by taking off the back cover and cleaning around the switch.
Qué necesitas
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove any visible debris that may be blocking the CHP Mode Switch.
Using the Q-tip gently wipe away any dust, dirt or residue, in and around the switch.
Once you are sure the switch is clean, test it gently by sliding it back and forth between the 'C', the 'H', and the 'P'. If the switch is clean there should be very little resistance and the switch should glide smoothly from one mode to the next.
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Una persona más ha completado esta guía.
