Introducción
The purpose of this guide is to fix/prevent joystick drift in your PS3 DualShock controller. This guide will show you step by step, how you can remove the dust and dirt particles which are trapped deep within your controller and may be the cause for your joysticks not functioning properly.
Keep in mind this guide is more of a cleaning/maintenance guide, and may not be able to resolve hardware failure. Following this guide will definitely help keep your PS3 controller clean and greatly lower the chance of getting that frustrating joystick drift which ruins your gaming experience.
Qué necesitas
Use a Phillips #1 screwdriver to remove the five 7.2 mm Phillips screws which hold the back shell to the controller.
If this maintenance did not fix your joystick drift, you may need to replace the joysticks altogether.
2 personas más completaron esta guía.
Un comentario
This guide is very helpful to all the users of PS3 as this is commonly occurring problem in the gaming console controller. This quick fix can save people a lot of money from not sending controller to PS service station for repair. I really liked how detailed each step is described with proper instruction and to the point. The tools you used liked toothpicks and cotton swaps, are also some of the things which are easily available at everyone's house and there's no special need to go to market for it, which makes the fix much more easier.
