Saltar al contenido principal
How to Fix the Side Pocket's Elastic on a Backpack
Qué necesitas
  1. How to Fix the Side Pocket's Elastic on a Backpack, How to Fix the Side Pocket's Elastic on a Backpack: paso 1, imagen 1 de 1
    • Trim any excess thread and frayed edges from the fabric with your scissors.
  2. How to Fix the Side Pocket's Elastic on a Backpack: paso 2, imagen 1 de 1
    • Stretch the elastic to match in length with the fabric.
  3. How to Fix the Side Pocket's Elastic on a Backpack: paso 3, imagen 1 de 1
    • Tuck the fabric edge back into the elastic.
  4. How to Fix the Side Pocket's Elastic on a Backpack: paso 4, imagen 1 de 1
    • Pin the fabric and elastic together.
    • Working with needles and pins can be dangerous.
  5. How to Fix the Side Pocket's Elastic on a Backpack: paso 5, imagen 1 de 1
    • Begin stitching the fabric and elastic together.
    • Start about one centimeter before the tear begins.
  6. How to Fix the Side Pocket's Elastic on a Backpack: paso 6, imagen 1 de 1
    • Continue stitching and remove pins when you sew past the part they're holding together.
  7. How to Fix the Side Pocket's Elastic on a Backpack: paso 7, imagen 1 de 1
    • Stitch until you have passed the end of the tear by about a centimeter.
  8. How to Fix the Side Pocket's Elastic on a Backpack: paso 8, imagen 1 de 1
    • End the stitch by tying a small knot close to where the thread passes through the fabric.
  9. How to Fix the Side Pocket's Elastic on a Backpack: paso 9, imagen 1 de 1
    • Cut the thread just above the knot so there is little excess.
  10. How to Fix the Side Pocket's Elastic on a Backpack: paso 10, imagen 1 de 1
    • Clean your work space and put away the tools
    • Congratulations, you're done!
Conclusión
Una persona más ha completado esta guía.
Emily Burnside
Miembro Desde 09/29/15
155 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-6, Green Fall 2015 Miembro de Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 99
Todo El Tiempo: 8,284
