Saltar al contenido principal
How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer
Qué necesitas
  1. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer, How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 1, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer, How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 1, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer, How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 1, imagen 3 de 3
    • Hold the door while removing it from the dryer so that it doesn't fall and break.
    • Remove the two 150 mm Phillips #2 screws from each of the two hinges on the inside of the door.
    • Remove the door.
  2. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 2, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 2, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 2, imagen 3 de 3
    • In order to prevent scratching or damage, place the door on a soft or protected surface
    • Remove the sixteen 150 mm Phillips #2 screws from the door.
  3. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 3, imagen 1 de 2 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 3, imagen 2 de 2
    • Gently pry open the inside panel of the door using a spudger or medium flathead screwdriver.
    • Remove the inside panel from the door.
  4. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 4, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 4, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 4, imagen 3 de 3
    • Remove the two 140 mm Phillips #2 screws from both the hook and the latch on the inside panel.
    • Swap the positions of the hook and the latch on the door.
    • Reattach the two screws to both the hook and the latch on the inside panel.
  5. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 5, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 5, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 5, imagen 3 de 3
    • Remove the two Phillips #2 140mm screws from each of the two hinges.
    • Swap the positions of the two hinges and the two gray cover caps.
    • Reattach the two screws on each of the two hinges.
  6. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 6, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 6, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 6, imagen 3 de 3
    • Remount the inside door panel to the door.
    • Reattach the sixteen 150 mm Phillips #2 screws to the door.
  7. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 7, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 7, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 7, imagen 3 de 3
    • Remove the two plastic cover caps on the dryer front gently, using a spudger or medium flat-head screwdriver.
    • Reattach the two plastic cover caps on the opposite side of the dryer front.
  8. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 8, imagen 1 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 8, imagen 2 de 3 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 8, imagen 3 de 3
    • Hold the door while reattaching it to the dryer so that it doesn't fall and break.
    • Reattach the door to the dryer using two 150 mm Phillips #2 screws on each of the two hinges.
  9. How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 9, imagen 1 de 2 How to Fix the Door Swing Direction of an LG DLEX5170W SteamDryer Clothes Dryer: paso 9, imagen 2 de 2
    • Test the alignment and door latch by opening and closing the door.
Conclusión
Reversing the dryer door swing is a simple and quick process. Completing this project can save you time and frustration by allowing your dryer door to open freely in the direction you need.
2 personas más completaron esta guía.
Un comentario
Directions are very clear and accurate. Not difficult!
Colin Ponder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 89
Todo El Tiempo: 4,008
