Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix an Overheating Desktop Computer
Qué necesitas
    1. How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: paso 1, imagen 1 de 3 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: paso 1, imagen 2 de 3 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: paso 1, imagen 3 de 3
      • Remove the screws from the side tempered glass panel using your hands.
      • Remove the front panel cover by applying a pulling force to the grip.
      • The position of the grip varies in case designs.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Fix an Overheating Desktop Computer: paso 2, imagen 1 de 1
      • Clean the front panel dust filter using a tissue or a cloth.
      • This step assures the internal components can easily access fresh air without dust accretion.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Fix an Overheating Desktop Computer: paso 3, imagen 1 de 3 How to Fix an Overheating Desktop Computer: paso 3, imagen 2 de 3 How to Fix an Overheating Desktop Computer: paso 3, imagen 3 de 3
      • Remove the screws that are connecting the CPU cooler and wires to the motherboard.
      • This applies to most AMD and Intel CPU brackets.
      • If you are still not sure about how to remove the cooler, refer to your motherboard’s manual guide for more information.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Fix an Overheating Desktop Computer: paso 4, imagen 1 de 1
      • Remove the CPU from the motherboard by raising the retention arm. Lay the CPU carefully on a soft surface to avoid damaging him by deforming some pins.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Fix an Overheating Desktop Computer: paso 5, imagen 1 de 2 How to Fix an Overheating Desktop Computer: paso 5, imagen 2 de 2
      • Use a tissue to gently clean off the leftover thermal compound.
      • Apply a small amount of thermal paste (or liquid metal) to the surface of the CPU.
      • You can refer to the Cómo aplicar pasta térmica guide for more information.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Fix an Overheating Desktop Computer: paso 6, imagen 1 de 3 How to Fix an Overheating Desktop Computer: paso 6, imagen 2 de 3 How to Fix an Overheating Desktop Computer: paso 6, imagen 3 de 3
      • Reattach the screws that connect the CPU cooler and wires to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Fix an Overheating Desktop Computer: paso 7, imagen 1 de 3 How to Fix an Overheating Desktop Computer: paso 7, imagen 2 de 3 How to Fix an Overheating Desktop Computer: paso 7, imagen 3 de 3
      • Mount two 120 mm type case fans on top of the case as an addition to exhausting hot air. You need at least four screws (two for each fan mounting diagonally) to mount the fans. (I recommend eight screws.)
      • This process improves the airflow inside the case because the heat generated by the CPU and the GPU will dissipate faster.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Fix an Overheating Desktop Computer: paso 8, imagen 1 de 1
      • Replace the screws from the side tempered glass panel using your hands.
      • Reattach the front panel cover.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Fix an Overheating Desktop Computer: paso 9, imagen 1 de 2 How to Fix an Overheating Desktop Computer: paso 9, imagen 2 de 2
      • Run the system and check for its cooling performance. When your system is on heavy workload, you can increase the fan speed of either the CPU or GPU for better heat dissipation.
      • Check the temperature of your CPU and increase the cooler fan speed by using SpeedFan.
      • Check your GPU temperature and increase the fan speed by using MSI Afterburner.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
6 personas más completaron esta guía.
Quan Nguyen
Miembro Desde 05/11/20
304 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 70
Todo El Tiempo: 5,748
