Saltar al contenido principal
How to Fix a broken Fan
Qué necesitas
  1. How to Fix a broken Fan, I am applying  Machine Oil to the Fan Rotor: paso 1, imagen 1 de 2 How to Fix a broken Fan, I am applying  Machine Oil to the Fan Rotor: paso 1, imagen 2 de 2
    • Take out the front metal grill.
    • By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
  2. How to Fix a broken Fan: paso 2, imagen 1 de 2 How to Fix a broken Fan: paso 2, imagen 2 de 2
    • Turn the knob to take out the blade cap.
    • Spin the knob counterclockwise. This way, you are loosening the knob.
  3. How to Fix a broken Fan: paso 3, imagen 1 de 2 How to Fix a broken Fan: paso 3, imagen 2 de 2
    • Loosen the plastic nut on the rear grille in order to take the rear grille out.
  4. How to Fix a broken Fan: paso 4, imagen 1 de 2 How to Fix a broken Fan: paso 4, imagen 2 de 2
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. How to Fix a broken Fan: paso 5, imagen 1 de 2 How to Fix a broken Fan: paso 5, imagen 2 de 2
    • Apply machine oil onto the rusted parts.
    • Take the machine oil and make sure you apply the oil to the around fan rotor
    • Let the oil stay for about 5 minutes
    • Do not spill the oil on the surface or let the oil go into the rotor.
  6. How to Fix a broken Fan: paso 6, imagen 1 de 2 How to Fix a broken Fan: paso 6, imagen 2 de 2
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. How to Fix a broken Fan: paso 7, imagen 1 de 1
    • Place back the fan rear grill, pick up the plastic grill nut.
    • fit in the hole and screw down the fan rear grill upon the fan motor.
  8. How to Fix a broken Fan: paso 8, imagen 1 de 1
    • Place the blade right back into the motor pin.
    • Take the blade, make sure the blade sit on the fan edges.
  9. How to Fix a broken Fan: paso 9, imagen 1 de 1
    • Take the circlip, spin the circlip right on the blade, ensure it is tight.
  10. How to Fix a broken Fan: paso 10, imagen 1 de 1
    • Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
    • Then lock the metal piece, this way the front and the rear grilles are locked.
    • If the metal piece do not align, you would have issues locking the grilles to each other.
Conclusión
2 personas más completaron esta guía.
TUOYO FABIYI
Miembro Desde 09/08/23
238 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 28
Todo El Tiempo: 140
