Introducción
If your COMFORTMATE FJYPD16H2 fan blade case is wobbling or moves when you pick the fan up, use this guide to repair it.
The blade case is the part around the fan blade and is there to protect you from the fast spinning blade.
Be careful of any broken parts as the edges of the plastic are sharp enough to cut skin.
You will need a piece of cloth or a paper towel to protect you when handling the fan blade in steps 4 and 10; safety gloves will also work.
Qué necesitas
Disconnect the fan from the power source.
Casi Terminas!
Linea de Meta
