Saltar al contenido principal
How to Fix a Whirlpool WDF330PAHW Door Latch
Qué necesitas
  1. How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: paso 1, imagen 1 de 2 How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: paso 1, imagen 2 de 2
    • Open the dishwasher door and look for the retaining screws around the side edge and top edge of the dishwasher door.
  2. How to Fix a Whirlpool WDF330PAHW Door Latch: paso 2, imagen 1 de 1
    • Using a T8 Torx screwdriver remove the two screws by turning counter clockwise.
  3. How to Fix a Whirlpool WDF330PAHW Door Latch: paso 3, imagen 1 de 2 How to Fix a Whirlpool WDF330PAHW Door Latch: paso 3, imagen 2 de 2
    • Lift the inner panel enough that you can loosen the two securing bolts on the door latch with the wrench.
    • When loosening the two bolts, leave them in and don't remove them.
  4. How to Fix a Whirlpool WDF330PAHW Door Latch: paso 4, imagen 1 de 2 How to Fix a Whirlpool WDF330PAHW Door Latch: paso 4, imagen 2 de 2
    • Carefully raise the dishwasher door to align the door latch with the strike plate.
    • Watch fingers while raising dishwasher door.
  5. How to Fix a Whirlpool WDF330PAHW Door Latch: paso 5, imagen 1 de 1
    • Hold the door latch with your finger tips to align the door latch.
    • Then lower the door and tighten the door latch securing bolts.
  6. How to Fix a Whirlpool WDF330PAHW Door Latch: paso 6, imagen 1 de 1
    • Install the inner door panel retaining screws.
    • Proceed to tighten two screws with the T8 Torx screwdriver.
    • When tightening the two screws turn clockwise.
    • Then close the dishwasher door.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 77
Todo El Tiempo: 2,560
