Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Tunneling Candle
Qué necesitas
    1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: paso 1, imagen 1 de 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: paso 1, imagen 2 de 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: paso 1, imagen 3 de 3
      • Fill any kind of dish with hot water.
      • Add any brand of dish soap or hand soap to the water.
      • Mix the soap with water using a spoon.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Fix a Tunneling Candle: paso 2, imagen 1 de 2 How to Fix a Tunneling Candle: paso 2, imagen 2 de 2
      • Place the candle inside the mix of water and soap.
      • Let the jar soak inside the pot.
      • Make sure the area on the jar that has a label is completely soaked.
      • After 5 to 10 minutes, remove the candle from the dish.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Fix a Tunneling Candle: paso 3, imagen 1 de 1
      • Use a sponge to wash and remove the label from the jar.
      • Removing the label helps you have a cleaner fix as it prevents the label from peeling off inside the boiling water and damaging your pot in future steps.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Fix a Tunneling Candle: paso 4, imagen 1 de 3 How to Fix a Tunneling Candle: paso 4, imagen 2 de 3 How to Fix a Tunneling Candle: paso 4, imagen 3 de 3
      • Fill another pot with water and place it on the stove.
      • Turn the stove to high heat.
      • Wait until the water is simmering.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Fix a Tunneling Candle: paso 5, imagen 1 de 3 How to Fix a Tunneling Candle: paso 5, imagen 2 de 3 How to Fix a Tunneling Candle: paso 5, imagen 3 de 3
      • Use oven mitts to place the candle inside the pot.
      • Wait 15 to 30 minutes for the wax to be fully melted.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Fix a Tunneling Candle: paso 6, imagen 1 de 3 How to Fix a Tunneling Candle: paso 6, imagen 2 de 3 How to Fix a Tunneling Candle: paso 6, imagen 3 de 3
      • While waiting for the wax to melt, grab two coffee stir sticks or similar objects, and tape them into a cross.
      • In this guide, I am using incense sticks.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Fix a Tunneling Candle: paso 7, imagen 1 de 3 How to Fix a Tunneling Candle: paso 7, imagen 2 de 3 How to Fix a Tunneling Candle: paso 7, imagen 3 de 3
      • Take the candle out of the pot using oven mitts.
      • Place the melted candle on a flat surface.
      • Remember to turn off the stove.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Fix a Tunneling Candle: paso 8, imagen 1 de 2 How to Fix a Tunneling Candle: paso 8, imagen 2 de 2
      Herramienta utilizada en este paso:
      • Use a pair of tweezers to grab and pull out the burnt wick of the candle.
      • Do not touch the hot wax with your fingers; use tweezers.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Fix a Tunneling Candle: paso 9, imagen 1 de 3 How to Fix a Tunneling Candle: paso 9, imagen 2 de 3 How to Fix a Tunneling Candle: paso 9, imagen 3 de 3
      • Place the cross that you made from the sticks on the edges of the candle jar.
      • Insert two new candle wicks inside the wax from the metal side.
      • Make sure the wicks are not close together.
      • Twist the wick around the sticks to prevent them from moving.
      Pregunta a FixBot
      Agregar Comentario
    10. How to Fix a Tunneling Candle: paso 10, imagen 1 de 3 How to Fix a Tunneling Candle: paso 10, imagen 2 de 3 How to Fix a Tunneling Candle: paso 10, imagen 3 de 3
      • Wait for the wax to harden and remove the sticks.
      • Trim the candle wick to 1/4 inch.
      • You have fixed your tunneling candle.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
2 personas más completaron esta guía.
[deleted]
Miembro Desde 01/18/21
245 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 32
Ultimos 30 días: 103
Todo El Tiempo: 2,151
