Saltar al contenido principal
How to Fix a Torn Slipper
Qué necesitas
  1. How to Fix a Torn Slipper, Glue up the vamp of the shoe: paso 1, imagen 1 de 2 How to Fix a Torn Slipper, Glue up the vamp of the shoe: paso 1, imagen 2 de 2
    • Use glue to glue up the torn part of the vamp (the top part of the shoe)
    • This is done to make it easier for the later stage. if the vamp wasn't broken, this step can be skipped.
  2. How to Fix a Torn Slipper, Measure the cloth you need: paso 2, imagen 1 de 3 How to Fix a Torn Slipper, Measure the cloth you need: paso 2, imagen 2 de 3 How to Fix a Torn Slipper, Measure the cloth you need: paso 2, imagen 3 de 3
    • Grab a piece of cloth and measure the amount needed to fix your shoe and cut it out.
  3. How to Fix a Torn Slipper, Glue the cloth to the shoe: paso 3, imagen 1 de 3 How to Fix a Torn Slipper, Glue the cloth to the shoe: paso 3, imagen 2 de 3 How to Fix a Torn Slipper, Glue the cloth to the shoe: paso 3, imagen 3 de 3
    • Glue the piece of cloth onto the shoe.
    • This step isn't needed if you are a pro, glue was used for holding the shoe and the cloth for easy sewing.
  4. How to Fix a Torn Slipper, Sewing the cloth to the shoe: paso 4, imagen 1 de 3 How to Fix a Torn Slipper, Sewing the cloth to the shoe: paso 4, imagen 2 de 3 How to Fix a Torn Slipper, Sewing the cloth to the shoe: paso 4, imagen 3 de 3
    • Now poke your thread over your needle
    • After you poke your thread into the needle, start sewing back and front, sew all the way around the cloth.
    • Be careful not to poke your hand while you are sewing
  5. How to Fix a Torn Slipper, Glue fixed vamp to the bottom of the shoe: paso 5, imagen 1 de 2 How to Fix a Torn Slipper, Glue fixed vamp to the bottom of the shoe: paso 5, imagen 2 de 2
    • Use glue to hold the vamp and the bottom of the shoe together.
    • This is similar to step 3, if you are a pro with sewing you can skip this step.
  6. How to Fix a Torn Slipper, Sew the bottom and the vamp together.: paso 6, imagen 1 de 3 How to Fix a Torn Slipper, Sew the bottom and the vamp together.: paso 6, imagen 2 de 3 How to Fix a Torn Slipper, Sew the bottom and the vamp together.: paso 6, imagen 3 de 3
    • Now sew the top and bottom of the shoe together. Poke in from the side and down the bottom again and again.
    • If it is hard to poke through, you can always use something hard to help with pushing the needle through.
  7. How to Fix a Torn Slipper, The end: paso 7, imagen 1 de 2 How to Fix a Torn Slipper, The end: paso 7, imagen 2 de 2
    • Now, this is ready for use.
    • You can always use a thread and cloth that fit the colour of your shoe to look nice.
Conclusión
This isn’t a very hard guide and can be performed by anyone who has enough time and tools to complete it.
Una persona más ha completado esta guía.
jia liu
Miembro Desde 09/19/21
171 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 71
Todo El Tiempo: 2,641
