Saltar al contenido principal
How to Fix a Tear in a Jacket Lining
Qué necesitas
  1. How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: paso 1, imagen 1 de 3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: paso 1, imagen 2 de 3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: paso 1, imagen 3 de 3
    • Turn the jacket inside out.
  2. How to Fix a Tear in a Jacket Lining: paso 2, imagen 1 de 2 How to Fix a Tear in a Jacket Lining: paso 2, imagen 2 de 2
    • Put the thread through the needle hole.
    • Use thread that is the same color as the material you are sewing.
  3. How to Fix a Tear in a Jacket Lining: paso 3, imagen 1 de 3 How to Fix a Tear in a Jacket Lining: paso 3, imagen 2 de 3 How to Fix a Tear in a Jacket Lining: paso 3, imagen 3 de 3
    • Take the two ends of the thread and knot them together.
  4. How to Fix a Tear in a Jacket Lining: paso 4, imagen 1 de 2 How to Fix a Tear in a Jacket Lining: paso 4, imagen 2 de 2
    • Cut the excess thread off.
  5. How to Fix a Tear in a Jacket Lining: paso 5, imagen 1 de 3 How to Fix a Tear in a Jacket Lining: paso 5, imagen 2 de 3 How to Fix a Tear in a Jacket Lining: paso 5, imagen 3 de 3
    • Push the needle through the fabric and pull it between the two threads to create a knot.
    • This prevents the thread from sliding through the fabric as you are sewing.
  6. How to Fix a Tear in a Jacket Lining: paso 6, imagen 1 de 3 How to Fix a Tear in a Jacket Lining: paso 6, imagen 2 de 3 How to Fix a Tear in a Jacket Lining: paso 6, imagen 3 de 3
    • Place one stitch on one side then place another one on the other side of the fabric.
    • Make sure the stitches are parallel and evenly distributed or the seams will not look straight.
    • Repeat this process until you have stitched down the length of the tear.
  7. How to Fix a Tear in a Jacket Lining: paso 7, imagen 1 de 2 How to Fix a Tear in a Jacket Lining: paso 7, imagen 2 de 2
    • Pull the thread through.
  8. How to Fix a Tear in a Jacket Lining: paso 8, imagen 1 de 3 How to Fix a Tear in a Jacket Lining: paso 8, imagen 2 de 3 How to Fix a Tear in a Jacket Lining: paso 8, imagen 3 de 3
    • Close the stitch.
  9. How to Fix a Tear in a Jacket Lining: paso 9, imagen 1 de 2 How to Fix a Tear in a Jacket Lining: paso 9, imagen 2 de 2
    • Cut off the excess thread off after securing the stitch.
  10. How to Fix a Tear in a Jacket Lining: paso 10, imagen 1 de 2 How to Fix a Tear in a Jacket Lining: paso 10, imagen 2 de 2
    • This is the final product.
Conclusión
If you mess up on a stitch, you can always cut and pull it out and start all over again.
2 personas más completaron esta guía.
Electra Pyatt
Miembro Desde 03/22/21
205 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 44
Ultimos 30 días: 168
Todo El Tiempo: 5,926
