Saltar al contenido principal
How to Fix a Sticking Deadbolt
Qué necesitas
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: paso 1, imagen 1 de 2 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: paso 2, imagen 1 de 2 How to Fix a Sticking Deadbolt: paso 2, imagen 2 de 2
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: paso 3, imagen 1 de 1
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: paso 4, imagen 1 de 2 How to Fix a Sticking Deadbolt: paso 4, imagen 2 de 2
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: paso 5, imagen 1 de 1
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: paso 6, imagen 1 de 2 How to Fix a Sticking Deadbolt: paso 6, imagen 2 de 2
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: paso 7, imagen 1 de 2 How to Fix a Sticking Deadbolt: paso 7, imagen 2 de 2
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: paso 8, imagen 1 de 1
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: paso 9, imagen 1 de 3 How to Fix a Sticking Deadbolt: paso 9, imagen 2 de 3 How to Fix a Sticking Deadbolt: paso 9, imagen 3 de 3
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: paso 10, imagen 1 de 1
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Conclusión
After following this fast fix guide, the sticking deadbolt should be fixed.
5 personas más completaron esta guía.
Equipo
Texas Tech, Team 22-5, Rauch Spring 2016 Miembro de Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 Miembros
1 Guía escrita
Un comentario
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 133
Todo El Tiempo: 39,082
