Introducción
Use this guide to fix the broken clicker in your Razer Naga Trinity gaming mouse.
Each mouse has a fixed maximum number of clicks. When the mouse is used for a long time, the clicker of the mouse will have problems. At this time, you will need to manually disassemble the mouse for maintenance.
Make sure you do not use too much force; the parts inside the mouse are sometimes very easy to damage.
This guide is not only applicable to this model,—other mice can also be repaired with this guide, but the internal structure may be different.
Qué necesitas
Remove the three pads from the bottom of the mouse.
Remove the four screws beneath the pads using a JIS #1 screwdriver.
4 personas más completaron esta guía.
Un comentario
On the latest version of the mouse, the clicker button can no longer be opened...
