Saltar al contenido principal
How to Fix a Non-Sticky Cutting Mat
Qué necesitas
  1. How to Fix a Non-Sticky Cutting Mat, How to Fix a Non-Sticky Cutting Mat: paso 1, imagen 1 de 1
    • Place the non-sticky mat on a flat surface.
  2. How to Fix a Non-Sticky Cutting Mat: paso 2, imagen 1 de 1
    • Spray the non-sticky cutting mat with a spray cleaner covering the entire mat.
  3. How to Fix a Non-Sticky Cutting Mat: paso 3, imagen 1 de 1
    • Let it sit for 5-10 minutes.
  4. How to Fix a Non-Sticky Cutting Mat: paso 4, imagen 1 de 1
    • Use a scraper to gently push the dirt off the mat that is causing your cutting mat not to be sticky.
  5. How to Fix a Non-Sticky Cutting Mat: paso 5, imagen 1 de 1
    • Once all the dirt is removed, let it air dry.
  6. How to Fix a Non-Sticky Cutting Mat: paso 6, imagen 1 de 1
    • Once dry, make sure to cover the cutting mat with its plastic cover to avoid the dust sticking to it.
Linea de Meta
April Pantaleon
Miembro Desde 09/20/20
349 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 361
