Introducción
Are you tired of people complaining about the sound of your punching bag? Are you worried if you punch hard your neighbors will wake up? WELL WORRY NO MORE!
This descriptive guide will help you ELIMINATE the annoying sound that comes from punching your heavy bag! We will add a Swivel Hook and a Spring which will allow smooth, 360-rotation of the punching bag.
Heavy Punching Bags are known to cause an immense amount of noise/sounds when being used. Most of the noise is caused due to the ceiling mount that the bag is attached to. The ceiling mount used in this guide is: ‘Everlast Heavy Bag Ceiling Mount’. This guide is important because it will help to get rid of the annoying sounds of the punching bag as well as reduce the risk of the bag falling on top of the user while in use.
To avoid potential hazards, make sure to remove the heavy punching bag carefully with the help of someone. Also, when done with the guide, tighten the screws of the ceiling mount appropriately.
Qué necesitas
This is an unsafe attachment of the bag to the ceiling mount. Too much pressure on the ceiling mount can lead to it breaking, therefore making the bag dangerous to its surroundings.
Un comentario
Tighten any loose screws, bolts, or nuts, and make sure the mount is securely fastened to the ceiling. If the noise persists, try adding some padding between the mount and the ceiling. This can be achieved by using rubber or foam mats, or even by simply placing folded towels between the mount and the ceiling. By taking these steps to fix a noisy punching bag ceiling mount, you can enjoy a more peaceful and productive workout. With the right equipmenta good punching bag and the best starter boxing gloves, you can train safely and effectively, and work towards achieving your fitness and boxing goals.
