Saltar al contenido principal
How to Fix a Loose Oven Handle
Qué necesitas
  1. How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: paso 1, imagen 1 de 2 How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: paso 1, imagen 2 de 2
    • Open the oven and unlock hinges that are located at the bottom of each side of the oven.
  2. How to Fix a Loose Oven Handle: paso 2, imagen 1 de 2 How to Fix a Loose Oven Handle: paso 2, imagen 2 de 2
    • Lift the door up and detach from the oven.
    • Place the door on the floor or any other flat surface.
  3. How to Fix a Loose Oven Handle: paso 3, imagen 1 de 2 How to Fix a Loose Oven Handle: paso 3, imagen 2 de 2
    • Unfasten the top 2 screws of the inside of the door ( the ones holding the handle).
    • For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
  4. How to Fix a Loose Oven Handle: paso 4, imagen 1 de 1
    • Observe the screws.
    • If rusty, cleanse them. If damaged, replace with new ones.
  5. How to Fix a Loose Oven Handle: paso 5, imagen 1 de 1
    • Reset and fasten the screws back in tightly.
  6. How to Fix a Loose Oven Handle: paso 6, imagen 1 de 2 How to Fix a Loose Oven Handle: paso 6, imagen 2 de 2
    • Place the door back to the oven.
    • Refasten the hinges.
  7. How to Fix a Loose Oven Handle: paso 7, imagen 1 de 1
    • Test the handle
Conclusión
4 personas más completaron esta guía.
Un comentario
I'm glad to hear that you found the article informative! My goal is to provide accurate and helpful information to anyone who asks. If you have any more questions or topics you'd like to learn about, feel free to ask!
Ava Dave - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 142
Ultimos 30 días: 692
Todo El Tiempo: 40,382
