Saltar al contenido principal
How to Fix a Loose Light Socket on a Lamp Model L37721
Qué necesitas
  1. How to Fix a Loose Light Socket on a Lamp Model L37721, How to Fix a Loose Light Socket on a Lamp Model L37721: paso 1, imagen 1 de 1
    • Unplug the lamp from the electrical socket.
    • Ensure that there is no electrical charge in the lamp by turning the lamp on and off.
  2. How to Fix a Loose Light Socket on a Lamp Model L37721: paso 2, imagen 1 de 3 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 2, imagen 2 de 3 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 2, imagen 3 de 3
    • Turn the lamp shade knob in a counterclockwise direction to remove it.
    • Lift the lampshade to remove it.
  3. How to Fix a Loose Light Socket on a Lamp Model L37721: paso 3, imagen 1 de 2 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 3, imagen 2 de 2
    • Turn the light bulb in a counterclockwise direction to remove it.
  4. How to Fix a Loose Light Socket on a Lamp Model L37721: paso 4, imagen 1 de 2 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 4, imagen 2 de 2
    • Lift the tabs up from the base.
    • Squeeze the lamp shade posts inward to release them.
  5. How to Fix a Loose Light Socket on a Lamp Model L37721: paso 5, imagen 1 de 2 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 5, imagen 2 de 2
    • Place the flat side of the screwdriver against the flat side of the nut inside of the base.
  6. How to Fix a Loose Light Socket on a Lamp Model L37721: paso 6, imagen 1 de 2 How to Fix a Loose Light Socket on a Lamp Model L37721: paso 6, imagen 2 de 2
    • While placing pressure against the nut, grip the light socket and turn it in a clockwise direction until it is tight against the base.
Conclusión
Robert McNabb
Miembro Desde 03/26/20
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 73
Todo El Tiempo: 5,622
