Saltar al contenido principal
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: paso 1, imagen 1 de 1
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: paso 2, imagen 1 de 1
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: paso 3, imagen 1 de 2 How to Fix a Loose Cookware Lid Handle: paso 3, imagen 2 de 2
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: paso 4, imagen 1 de 2 How to Fix a Loose Cookware Lid Handle: paso 4, imagen 2 de 2
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: paso 5, imagen 1 de 3 How to Fix a Loose Cookware Lid Handle: paso 5, imagen 2 de 3 How to Fix a Loose Cookware Lid Handle: paso 5, imagen 3 de 3
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: paso 6, imagen 1 de 2 How to Fix a Loose Cookware Lid Handle: paso 6, imagen 2 de 2
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: paso 7, imagen 1 de 3 How to Fix a Loose Cookware Lid Handle: paso 7, imagen 2 de 3 How to Fix a Loose Cookware Lid Handle: paso 7, imagen 3 de 3
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
Conclusión
Dinuk Warnapura
Miembro Desde 01/11/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 69
Todo El Tiempo: 1,951
