Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Loose Connection on a Power Strip
Qué necesitas
  1. How to Fix a Loose Connection on a Power Strip, How to Fix a Loose Connection on a Power Strip: paso 1, imagen 1 de 1
    • Before you start, make sure you unplug the power strip from the wall! It is very important, as you will get an electric shock if you do not do so.
    • Take out all the plugs on the power strip.
    Pregunta a FixBot
    Agregar Comentario
  2. How to Fix a Loose Connection on a Power Strip: paso 2, imagen 1 de 2 How to Fix a Loose Connection on a Power Strip: paso 2, imagen 2 de 2
    • Flip over the power strip.
    • Use a Phillips #0 screwdriver to take out the 6 mm screws on the back of the power strip.
    Pregunta a FixBot
    Agregar Comentario
  3. How to Fix a Loose Connection on a Power Strip: paso 3, imagen 1 de 2 How to Fix a Loose Connection on a Power Strip: paso 3, imagen 2 de 2
    • Separate the outer shell from the power strip.
    • Most of the outer shells can be separated out very easily after the screws are taken out.
    Pregunta a FixBot
    Agregar Comentario
  4. How to Fix a Loose Connection on a Power Strip: paso 4, imagen 1 de 2 How to Fix a Loose Connection on a Power Strip: paso 4, imagen 2 de 2
    • Locate two pairs of copper sheets for each socket.
    Pregunta a FixBot
    Agregar Comentario
  5. How to Fix a Loose Connection on a Power Strip: paso 5, imagen 1 de 3 How to Fix a Loose Connection on a Power Strip: paso 5, imagen 2 de 3 How to Fix a Loose Connection on a Power Strip: paso 5, imagen 3 de 3
    • Use a screwdriver to push the two copper sheets closer to each other. Do this on all the pairs of copper sheets without a solid connection.
    Pregunta a FixBot
    Agregar Comentario
  6. How to Fix a Loose Connection on a Power Strip: paso 6, imagen 1 de 2 How to Fix a Loose Connection on a Power Strip: paso 6, imagen 2 de 2
    • Install the outer shell back to the power strip.
    • Put the outer shell on it and press it to install.
    Pregunta a FixBot
    Agregar Comentario
  7. How to Fix a Loose Connection on a Power Strip: paso 7, imagen 1 de 2 How to Fix a Loose Connection on a Power Strip: paso 7, imagen 2 de 2
    • Flip over the power strip, and then use screwdriver to install all the screws back.
    Pregunta a FixBot
    Agregar Comentario
  8. How to Fix a Loose Connection on a Power Strip: paso 8, imagen 1 de 1
    • Plug the power strip into the wall socket, and then plug electric machine to the power strip to test that if the connection of power strip has improved.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
You’re all done!
Una persona más ha completado esta guía.
Xike Cao
Miembro Desde 09/19/21
219 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 40
Ultimos 30 días: 123
Todo El Tiempo: 3,812
