Saltar al contenido principal
How to Fix a Leaning Wooden Gate
Qué necesitas
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: paso 1, imagen 1 de 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: paso 1, imagen 2 de 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: paso 2, imagen 1 de 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: paso 3, imagen 1 de 3 How to Fix a Leaning Wooden Gate: paso 3, imagen 2 de 3 How to Fix a Leaning Wooden Gate: paso 3, imagen 3 de 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: paso 4, imagen 1 de 3 How to Fix a Leaning Wooden Gate: paso 4, imagen 2 de 3 How to Fix a Leaning Wooden Gate: paso 4, imagen 3 de 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: paso 5, imagen 1 de 2 How to Fix a Leaning Wooden Gate: paso 5, imagen 2 de 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: paso 6, imagen 1 de 2 How to Fix a Leaning Wooden Gate: paso 6, imagen 2 de 2
    • Remove the object you placed underneath.
Conclusión
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
Miembro Desde 09/08/23
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 37
Ultimos 30 días: 44
Todo El Tiempo: 253
