Saltar al contenido principal
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
Qué necesitas
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 1, imagen 1 de 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 1, imagen 2 de 2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 2, imagen 1 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 2, imagen 2 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 2, imagen 3 de 3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 3, imagen 1 de 1
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 4, imagen 1 de 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 4, imagen 2 de 2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 5, imagen 1 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 5, imagen 2 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 5, imagen 3 de 3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 6, imagen 1 de 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 6, imagen 2 de 2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 7, imagen 1 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 7, imagen 2 de 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: paso 7, imagen 3 de 3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
Conclusión
Your lock will not jam anymore!
Una persona más ha completado esta guía.
Manpreet Sahota
Miembro Desde 09/09/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 74
Ultimos 30 días: 299
Todo El Tiempo: 13,961
