Saltar al contenido principal
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
Qué necesitas
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 1, imagen 1 de 1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 2, imagen 1 de 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 2, imagen 2 de 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 2, imagen 3 de 3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 3, imagen 1 de 1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 4, imagen 1 de 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 4, imagen 2 de 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 4, imagen 3 de 3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 5, imagen 1 de 2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 5, imagen 2 de 2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 6, imagen 1 de 1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 7, imagen 1 de 1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 8, imagen 1 de 1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: paso 9, imagen 1 de 1
    • Turn the dial to a horizontal position to reopen the fuel line.
Conclusión
With the water out of the fuel line, the lawnmower should be ready for use.
2 personas más completaron esta guía.
Alonso Pantoja
Miembro Desde 01/24/22
223 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 102
Todo El Tiempo: 1,813
