Saltar al contenido principal
How to Fix a Hole in a Pant Pocket
Qué necesitas
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: paso 1, imagen 1 de 2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: paso 1, imagen 2 de 2
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: paso 2, imagen 1 de 2 How to Fix a Hole in a Pant Pocket: paso 2, imagen 2 de 2
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: paso 3, imagen 1 de 3 How to Fix a Hole in a Pant Pocket: paso 3, imagen 2 de 3 How to Fix a Hole in a Pant Pocket: paso 3, imagen 3 de 3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: paso 5, imagen 1 de 3 How to Fix a Hole in a Pant Pocket: paso 5, imagen 2 de 3 How to Fix a Hole in a Pant Pocket: paso 5, imagen 3 de 3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: paso 6, imagen 1 de 2 How to Fix a Hole in a Pant Pocket: paso 6, imagen 2 de 2
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: paso 7, imagen 1 de 1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Conclusión
Dolapo Ajose
Miembro Desde 09/20/21
220 Reputación
1 Guía escrita
Equipo
Un comentario
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 91
Todo El Tiempo: 3,984
