Saltar al contenido principal
How to Fix a Hole in Leggings by Hand Sewing
Qué necesitas
  1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: paso 1, imagen 1 de 3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: paso 1, imagen 2 de 3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: paso 1, imagen 3 de 3
    • Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
  2. How to Fix a Hole in Leggings by Hand Sewing: paso 2, imagen 1 de 1
    • Mishandling of the needle could result in minor or moderate injury.
    • Thread the needle by running the piece of thread through the eye, or opening, of the needle.
  3. How to Fix a Hole in Leggings by Hand Sewing: paso 3, imagen 1 de 1
    • Pull the thread through the needle until there are two equal halves of thread.
    • Tie a knot with the ends of the thread.
  4. How to Fix a Hole in Leggings by Hand Sewing: paso 4, imagen 1 de 1
    • Turn the leggings inside out.
    • This is so the sewing will be on the inside of the leggings.
  5. How to Fix a Hole in Leggings by Hand Sewing: paso 5, imagen 1 de 1
    • Smooth out the fabric around the hole.
  6. How to Fix a Hole in Leggings by Hand Sewing: paso 6, imagen 1 de 1
    • Pinch the fabric together.
    • Begin your stitch on one end of the hole.
  7. How to Fix a Hole in Leggings by Hand Sewing: paso 7, imagen 1 de 1
    • Use short stitches so that the thread will not break easily.
    • Make sure the hole is completely included in the stitches.
  8. How to Fix a Hole in Leggings by Hand Sewing: paso 8, imagen 1 de 1
    • Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
    • Make sure the knot is large enough so it doesn't slip through the stitches.
  9. How to Fix a Hole in Leggings by Hand Sewing: paso 9, imagen 1 de 1
    • Cut the loose thread above the new knot with scissors.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 37
Ultimos 7 días: 222
Ultimos 30 días: 1,175
Todo El Tiempo: 40,665
