Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Dress Strap With a Clasp
Qué necesitas
    1. How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: paso 1, imagen 1 de 3 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: paso 1, imagen 2 de 3 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: paso 1, imagen 3 de 3
      • Pull the end of the strap through the loop on the collar of the dress.
      • Locate the buckle along the length of the strap and feed the end of the strap under the opening of the buckle (closest to the strap).
      • Continue feeding the strap through the next opening of the buckle.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Fix a Dress Strap With a Clasp: paso 2, imagen 1 de 3 How to Fix a Dress Strap With a Clasp: paso 2, imagen 2 de 3 How to Fix a Dress Strap With a Clasp: paso 2, imagen 3 de 3
      • Roll the end of the strap 1/8".
      • Roll it one more time.
      • Compare the newly made loop to the other functioning strap to ensure the loops are the same length.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Fix a Dress Strap With a Clasp: paso 3, imagen 1 de 1
      • Secure the fold with the needle and thread.
      • Never use any part of your hand to brace the material as you push the needle through it, to avoid minor injuries.
      • For instructions on how to thread a needle, follow this tutorial: How to thread a needle.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Fix a Dress Strap With a Clasp: paso 4, imagen 1 de 2 How to Fix a Dress Strap With a Clasp: paso 4, imagen 2 de 2
      • Poke the needle through to one edge of the looped strap to begin securing the fold to the strap.
      • Begin sewing along the width of the strap, using a short stitch length (2.0 mm).
      Pregunta a FixBot
      Agregar Comentario
    5. How to Fix a Dress Strap With a Clasp: paso 5, imagen 1 de 3 How to Fix a Dress Strap With a Clasp: paso 5, imagen 2 de 3 How to Fix a Dress Strap With a Clasp: paso 5, imagen 3 de 3
      • To finish securing the fabric together, create a loop with the excess thread attached to the needle.
      • Use a quilter's knot to finish securing the fabric.
      • For more detail on performing a quilters knot, follow this link: Quilters Knot.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Fix a Dress Strap With a Clasp: paso 6, imagen 1 de 2 How to Fix a Dress Strap With a Clasp: paso 6, imagen 2 de 2
      • Pull the knot tightly.
      • Cut the excess thread with the scissors.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Luke Bartels
Miembro Desde 01/19/26
133 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 43
Ultimos 30 días: 150
Todo El Tiempo: 597
