Saltar al contenido principal
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
Qué necesitas
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 1, imagen 1 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 1, imagen 2 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 1, imagen 3 de 3
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 2, imagen 1 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 2, imagen 2 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 2, imagen 3 de 3
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 3, imagen 1 de 1
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 4, imagen 1 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 4, imagen 2 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 4, imagen 3 de 3
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 5, imagen 1 de 1
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 6, imagen 1 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 6, imagen 2 de 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 6, imagen 3 de 3
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 7, imagen 1 de 1
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: paso 8, imagen 1 de 1
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
Conclusión
2 personas más completaron esta guía.
Sydney Schuett
Miembro Desde 07/20/20
211 Reputación
1 Guía escrita
Equipo
Un comentario
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 44
Todo El Tiempo: 2,952
