Saltar al contenido principal
How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear
Qué necesitas
  1. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear, How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 1, imagen 1 de 2 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear, How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 1, imagen 2 de 2
    • Trim the edges of the fiberglass sheet into small strips that cover the crack on the mask.
    • The trimmed fiberglass strands should look like this! (second picture)
  2. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 2, imagen 1 de 1
    • Proceed to push the resin and sealant out into a container to mix.
    • Use latex gloves to protect your hands from the resin.
  3. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 3, imagen 1 de 2 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 3, imagen 2 de 2
    • Begin to mix the resin and the sealant together using the toothpicks.
  4. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 4, imagen 1 de 1
    • Mix in some of the fiberglass strands into the resin until the strands are fully saturated with resin.
    • Scoop up some of the resin and fiberglass mixture with the toothpick.
  5. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 5, imagen 1 de 2 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 5, imagen 2 de 2
    • Apply the fiber glass and resin combo onto the crack and, using another toothpick, arrange the fiberglass to cover the crack.
    • Repeat until the hole has been sufficiently covered.
  6. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 6, imagen 1 de 1
    • Let the resin dry.
    • The time will vary based on the resin, amount of solvent used, and weather conditions, so be sure to read the back of your resin container to estimate how long it will take to dry.
  7. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: paso 7, imagen 1 de 1
    • When you are done the final product should be covering the crack and completely airtight.
    • Check the mask to ensure that the crack is fully sealed.
    • If there is still pressure loss through the crack, apply more resin to the crack until it is sealed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 135
