Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer
Qué necesitas
  1. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 1, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 1, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 1, imagen 3 de 3
    • Unplug your device from all power and turn off the device as well.
    • Always remember to turn off the power for safety measures. Additionally, disconnect the main power cable from your PC (as indicated in the images) and you are safe to go.
    Pregunta a FixBot
    Agregar Comentario
  2. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 2, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 2, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 2, imagen 3 de 3
    • Using a screwdriver or potentially just your hands, remove the panel from the PC case. You might have to remove screws but cases vary.
    • If your case happens to have screws on the back panel, simply remove them, but do remember to correctly distribute all the screws in a cleared area so that you don’t lose any of them while performing additional steps later.
    Pregunta a FixBot
    Agregar Comentario
  3. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 3, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 3, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 3, imagen 3 de 3
    • Once the back panel of your PC case is opened, disconnect the graphics card from both the monitor and the motherboard.
    • Take a picture of how the wires are connected so that you don’t mess up when you try to put it back later.
    • Be gentle and careful working with connection wires. Connection wires are easy to find but are usually loose and vulnerable.
    Pregunta a FixBot
    Agregar Comentario
  4. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 4, imagen 1 de 1
    • Disconnect and separate the graphics card from the motherboard and the PC case.
    • Use a screwdriver to remove the screw(s) (1.2mm factory issued) on the side panel to separate your graphics card from both your motherboard and your PC. There's one more step before you can completely release your graphics card from your case.
    Pregunta a FixBot
    Agregar Comentario
  5. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 5, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 5, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 5, imagen 3 de 3
    • Notice the little black clip on the motherboard next to the graphics card. That is the release key.
    • If the clip is a bit too deep to reach, find a stick and press it down so that you can pull up your graphics card with no stress.
    • Pull out the graphics card and lay it down on a flat surface.
    Pregunta a FixBot
    Agregar Comentario
  6. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 6, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 6, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 6, imagen 3 de 3
    • The gold spike edge is usually identified as the connecting finger of many electronic parts.
    • Softly clean the connecting finger with a rubber. Remember to rub both sides of the connecting finger.
    Pregunta a FixBot
    Agregar Comentario
  7. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 7, imagen 1 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 7, imagen 2 de 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 7, imagen 3 de 3
    • Take out the RAM sticks. These RAM sticks are fixed and attached to the RAM slots on the motherboard. They can be easily damaged if you attempt to pull them out straight.
    • Loosen the clips on both sides of the RAM slot first and then unplug the RAM. It should be fairly easy once you unclip the slot.
    Pregunta a FixBot
    Agregar Comentario
  8. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 8, imagen 1 de 2 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: paso 8, imagen 2 de 2
    • Use the rubber to clean the connecting finger of the RAM.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Xie Zheng
Miembro Desde 02/02/22
181 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 52
Todo El Tiempo: 1,456
