Saltar al contenido principal
How to Fix a Button on an Umbrella
Qué necesitas
  1. How to Fix a Button on an Umbrella, How to Fix a Button on an Umbrella: paso 1, imagen 1 de 1
    • Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
  2. How to Fix a Button on an Umbrella: paso 2, imagen 1 de 2 How to Fix a Button on an Umbrella: paso 2, imagen 2 de 2
    • Remove the umbrella handle by pushing on the eject push-up button.
  3. How to Fix a Button on an Umbrella: paso 3, imagen 1 de 2 How to Fix a Button on an Umbrella: paso 3, imagen 2 de 2
    • Place a thin malleable metal in between the button’s connection to the metal projection.
  4. How to Fix a Button on an Umbrella: paso 4, imagen 1 de 2 How to Fix a Button on an Umbrella: paso 4, imagen 2 de 2
    • Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
  5. How to Fix a Button on an Umbrella: paso 5, imagen 1 de 1
    • Verify that the button is firmly fixated to the metal ejector.
  6. How to Fix a Button on an Umbrella: paso 6, imagen 1 de 2 How to Fix a Button on an Umbrella: paso 6, imagen 2 de 2
    • Proceed to push down on the button while placing the handle.
    • The button goes through the handles button crevice.
  7. How to Fix a Button on an Umbrella: paso 7, imagen 1 de 1
    • Verify that the button is firmly fixated on the metal ejector.
  8. How to Fix a Button on an Umbrella: paso 8, imagen 1 de 1
    • Pound a nail with a hammer to prevent the opening system from turning.
  9. How to Fix a Button on an Umbrella: paso 9, imagen 1 de 1
    • Return the screw to fixate the handle to the umbrella.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 23
Ultimos 7 días: 113
Ultimos 30 días: 453
Todo El Tiempo: 16,521
