Saltar al contenido principal
How to Fix a Broken Wig
Qué necesitas
  1. How to Fix a Broken Wig, How to Fix a Broken Wig: paso 1, imagen 1 de 2 How to Fix a Broken Wig, How to Fix a Broken Wig: paso 1, imagen 2 de 2
    • Brush out the wig with a comb. Use a brush if the wig is severely tangled.
    • Do not brush aggressively as you may tear out more pieces of the wig.
  2. How to Fix a Broken Wig: paso 2, imagen 1 de 3 How to Fix a Broken Wig: paso 2, imagen 2 de 3 How to Fix a Broken Wig: paso 2, imagen 3 de 3
    • Lay out the weft so it is not in a clump.
    • Comb out the weft so it is not tangled.
  3. How to Fix a Broken Wig: paso 3, imagen 1 de 3 How to Fix a Broken Wig: paso 3, imagen 2 de 3 How to Fix a Broken Wig: paso 3, imagen 3 de 3
    • Mount the wig on somewhere secure.
    • Clip up the hair out of the way of the damaged spot with hair clips.
  4. How to Fix a Broken Wig: paso 4, imagen 1 de 2 How to Fix a Broken Wig: paso 4, imagen 2 de 2
    • Line up wefts where you want to fill the damaged spot.
  5. How to Fix a Broken Wig: paso 5, imagen 1 de 3 How to Fix a Broken Wig: paso 5, imagen 2 de 3 How to Fix a Broken Wig: paso 5, imagen 3 de 3
    • Pin the lined up wefts in place with the pins so they don’t move around while working.
    • Use caution when working with pins and needles so you do not poke yourself.
  6. How to Fix a Broken Wig: paso 6, imagen 1 de 2 How to Fix a Broken Wig: paso 6, imagen 2 de 2
    • Thread a needle with a long strand of thread.
    • Double it over by pulling the needle to the middle of the thread, then bring both ends together to knot them.
  7. How to Fix a Broken Wig: paso 7, imagen 1 de 3 How to Fix a Broken Wig: paso 7, imagen 2 de 3 How to Fix a Broken Wig: paso 7, imagen 3 de 3
    • Sew the weft in at each of the non-elastic bands of the wig in the damaged area.
    • An overhand stitch (also called a whip stitch) is easy and works well for this fix.
    • Be sure to tie off any loose ends after you are done stitching.
    • If you need help with the stitch, here is a helpful link with instructions.
  8. How to Fix a Broken Wig: paso 8, imagen 1 de 3 How to Fix a Broken Wig: paso 8, imagen 2 de 3 How to Fix a Broken Wig: paso 8, imagen 3 de 3
    • Take out the pins and check to see if there is still damage and another weft is needed.
    • If the damage is still noticeable, repeat steps 1-8 with another weft. If not, you are ready to use your wig again!
  9. How to Fix a Broken Wig: paso 9, imagen 1 de 2 How to Fix a Broken Wig: paso 9, imagen 2 de 2
    • With a completed wig, you are ready to shine your best out to the world.
Conclusión
Una persona más ha completado esta guía.
Reid Dounias
Miembro Desde 10/26/18
172 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G3, Bender Fall 2018 Miembro de UC Davis, Team S2-G3, Bender Fall 2018
UCD-BENDER-F18S2G3
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 942
