Saltar al contenido principal
How to Fix a Broken Toilet Paper Holder
Qué necesitas
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: paso 1, imagen 1 de 1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
  2. How to Fix a Broken Toilet Paper Holder: paso 2, imagen 1 de 1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
  3. How to Fix a Broken Toilet Paper Holder: paso 3, imagen 1 de 3 How to Fix a Broken Toilet Paper Holder: paso 3, imagen 2 de 3 How to Fix a Broken Toilet Paper Holder: paso 3, imagen 3 de 3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
  4. How to Fix a Broken Toilet Paper Holder: paso 4, imagen 1 de 2 How to Fix a Broken Toilet Paper Holder: paso 4, imagen 2 de 2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
  5. How to Fix a Broken Toilet Paper Holder: paso 5, imagen 1 de 2 How to Fix a Broken Toilet Paper Holder: paso 5, imagen 2 de 2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
  6. How to Fix a Broken Toilet Paper Holder: paso 6, imagen 1 de 2 How to Fix a Broken Toilet Paper Holder: paso 6, imagen 2 de 2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
Linea de Meta
2 personas más completaron esta guía.
Andrew Nammour
Miembro Desde 07/05/20
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 76
Ultimos 30 días: 317
Todo El Tiempo: 23,371
