Saltar al contenido principal
How to Fix a Broken Necklace
Qué necesitas
  1. How to Fix a Broken Necklace, How to Fix a Broken Necklace: paso 1, imagen 1 de 1
    • Lay your chain necklace on a flat surface.
    • This will keep the chain from tangling.
  2. How to Fix a Broken Necklace: paso 2, imagen 1 de 1
    • Locate the broken link.
    • Place the pliers on the right of the small opening on the chain.
    • Keep your hand a few centimeters lower than the opening of the chain to avoid accidental injuries.
  3. How to Fix a Broken Necklace: paso 3, imagen 1 de 1
    • Pull one side of the link down slightly to make the gap in the chain larger using the pliers.
    • This opens up the chain allowing you to work with it easily.
  4. How to Fix a Broken Necklace: paso 4, imagen 1 de 2 How to Fix a Broken Necklace: paso 4, imagen 2 de 2
    • Repeat step three on the opposite side of the chain.
  5. How to Fix a Broken Necklace: paso 5, imagen 1 de 2 How to Fix a Broken Necklace: paso 5, imagen 2 de 2
    • Take both ends of the chain and hook them together.
  6. How to Fix a Broken Necklace: paso 6, imagen 1 de 2 How to Fix a Broken Necklace: paso 6, imagen 2 de 2
    • Close the chain by using the pliers to push the link to its original position.
  7. How to Fix a Broken Necklace: paso 7, imagen 1 de 1
    • Repeat step six to close the other chain link.
  8. How to Fix a Broken Necklace: paso 8, imagen 1 de 1
    • Your jewelry is ready to be worn!
Conclusión
This creative guide can be used for all accessories whether big or small, wide or thin. Now you can restore old, broken, accessories that still have a special place in your heart.
4 personas más completaron esta guía.
Salonee
Miembro Desde 04/09/15
263 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-4, Green Spring 2015 Miembro de Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Miembros
13 Guías creadas
2 comentarios
Always great to be able to repair and reuse broken jewelry. A tip on how to add a bright, metal jump ring or chain to an older, more tarnished necklace is to use the flame of a wooden match to burn the newer metal. It will give it an antique look. Try doing it on just one bit of metal to see how it reacts. And, always hold the metal with your pliers, not your hands, when you're burning it. Allow it to cool. Wipe off excess tarnish with a tissue. Note: this needs a wooden match, not a lighter.
Also, to polish sterling chains, you can use a q-tip with fireplace ashes. They work great!
janiceparsons - Contestar
Fixed a broken chain bracelet with your method!
Thanks a bunch :)
Mihai Patrascu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 3,455
