Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Broken Decorative Ceramic Bowl
Qué necesitas
    1. How to Fix a Broken Decorative Ceramic Bowl, How to Fix a Broken Decorative Ceramic Bowl: paso 1, imagen 1 de 1
      • Clean the broken ceramic with rubbing alcohol.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Fix a Broken Decorative Ceramic Bowl: paso 2, imagen 1 de 2 How to Fix a Broken Decorative Ceramic Bowl: paso 2, imagen 2 de 2
      • Mix epoxy to paste the pieces of ceramics together.
      • If you are using Epoxy that is not pre-mixed, combine the two-part Epoxy using a paper pad and wooden stick.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Fix a Broken Decorative Ceramic Bowl: paso 3, imagen 1 de 1
      • Apply Epoxy to the edges and place the broken ceramic pieces in their permanent location.
      • Press the broken pieces firmly together.
      • Epoxy will ooze out. Do not wipe off to avoid smearing.
      • Use the container of sand to help hold pieces in place.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Fix a Broken Decorative Ceramic Bowl: paso 4, imagen 1 de 2 How to Fix a Broken Decorative Ceramic Bowl: paso 4, imagen 2 de 2
      • Use clay for securing the attached pieces during the curing process.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Fix a Broken Decorative Ceramic Bowl: paso 5, imagen 1 de 1
      • Use the Exacto knife to remove the excess dried Epoxy from the bowl.
      • Be cautious while handling the tool. The blade is very sharp.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Fix a Broken Decorative Ceramic Bowl: paso 6, imagen 1 de 2 How to Fix a Broken Decorative Ceramic Bowl: paso 6, imagen 2 de 2
      • Check if the pieces are secure.
      • Let the bowl set for an hour before use.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Katelynn
Miembro Desde 11/05/24
133 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-3, Vidal-Chiesa Fall 2024 Miembro de UC Davis, Team 4-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G3
Miembros de 3
12 Guías creadas
1Guía Comentario
This is a helpful and easy-to-follow guide. I like that it focuses on repairing a decorative ceramic bowl instead of immediately replacing it, which is both cost-effective and environmentally friendly.
Pick low - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 87
Todo El Tiempo: 834
