Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Broken Ceramic Vase
Qué necesitas
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: paso 1, imagen 1 de 1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: paso 2, imagen 1 de 1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: paso 3, imagen 1 de 2 How to Fix a Broken Ceramic Vase: paso 3, imagen 2 de 2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: paso 4, imagen 1 de 1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: paso 5, imagen 1 de 1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: paso 6, imagen 1 de 2 How to Fix a Broken Ceramic Vase: paso 6, imagen 2 de 2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: paso 7, imagen 1 de 1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: paso 8, imagen 1 de 1
    • Let the paint dry for one hour on the vase and your repair is finished.
Linea de Meta
Una persona más ha completado esta guía.
1Guía Comentario
What kind of putty do you use?
Jill Martin Ward - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 62
Ultimos 30 días: 202
Todo El Tiempo: 5,155
