Saltar al contenido principal
How to Fix a Broken Ceramic Vase
Qué necesitas
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: paso 1, imagen 1 de 1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: paso 2, imagen 1 de 1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: paso 3, imagen 1 de 2 How to Fix a Broken Ceramic Vase: paso 3, imagen 2 de 2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: paso 4, imagen 1 de 1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: paso 5, imagen 1 de 1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: paso 6, imagen 1 de 2 How to Fix a Broken Ceramic Vase: paso 6, imagen 2 de 2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: paso 7, imagen 1 de 1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: paso 8, imagen 1 de 1
    • Let the paint dry for one hour on the vase and your repair is finished.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 24
Ultimos 30 días: 116
Todo El Tiempo: 1,375
