Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Fix a Broken Air-Dry Clay Figurine
Qué necesitas
    1. How to Fix a Broken Air-Dry Clay Figurine, How to Fix a Broken Air-Dry Clay Figurine: paso 1, imagen 1 de 1
      • Collect the air-dry clay fractures.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Fix a Broken Air-Dry Clay Figurine: paso 2, imagen 1 de 1
      • Brush out the clay debris from the clay piece's surface.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Fix a Broken Air-Dry Clay Figurine: paso 3, imagen 1 de 2 How to Fix a Broken Air-Dry Clay Figurine: paso 3, imagen 2 de 2
      • Preheat the hot glue gun.
      • Apply the hot glue onto the cracked surface.
      • Try to work quickly on this step. The hot glue dries and hardens very fast.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Fix a Broken Air-Dry Clay Figurine: paso 4, imagen 1 de 1
      • Attach the corresponding fractured pieces. Press and hold the clay for at least 10 seconds to allow the clay to set.
      • Strip away excess hot glue to avoid potential additional damage.
      • If there are multiple cracks, repair one fractured area at a time to prevent hassle.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Fix a Broken Air-Dry Clay Figurine: paso 5, imagen 1 de 2 How to Fix a Broken Air-Dry Clay Figurine: paso 5, imagen 2 de 2
      • Place a small amount of air-dry clay on the paint palette.
      • Apply some water to the air-dry clay and mix them with a brush or your fingers.
      • Add water gradually to avoid over-moisturizing the paste.
      • Continue mixing until the paste reaches a jam-like consistency.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Fix a Broken Air-Dry Clay Figurine: paso 6, imagen 1 de 3 How to Fix a Broken Air-Dry Clay Figurine: paso 6, imagen 2 de 3 How to Fix a Broken Air-Dry Clay Figurine: paso 6, imagen 3 de 3
      • Grab some clay paste and apply it along the cracked surface.
      • Smooth out the paste with your fingers or a brush.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Fix a Broken Air-Dry Clay Figurine: paso 7, imagen 1 de 1
      • Choose one of the following steps that fits the best:
      • Wait for the air-dry clay to fully dry and harden. This step takes at least 2 days.
      • Use a blow dryer to speed up the drying process. This step is optional, but the dry time can be shortened to 15 minutes.
      • Rushing to the next step without allowing the ornament to fully dry may result in additional damages.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Fix a Broken Air-Dry Clay Figurine: paso 8, imagen 1 de 1
      • Polish the repaired surface using sandpaper.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Fix a Broken Air-Dry Clay Figurine: paso 9, imagen 1 de 2 How to Fix a Broken Air-Dry Clay Figurine: paso 9, imagen 2 de 2
      • Paint the dried clay with the corresponding colors.
      Pregunta a FixBot
      Agregar Comentario
    10. How to Fix a Broken Air-Dry Clay Figurine: paso 10, imagen 1 de 2 How to Fix a Broken Air-Dry Clay Figurine: paso 10, imagen 2 de 2
      • Paint the repaired surface with glossy or matte varnish.
      • Wait for the varnish to be fully dried. This takes 1 day.
      • Do not use a blow dryer for this step. Varnish cannot be dried through hot air.
      Pregunta a FixBot
      Agregar Comentario
    11. How to Fix a Broken Air-Dry Clay Figurine: paso 11, imagen 1 de 2 How to Fix a Broken Air-Dry Clay Figurine: paso 11, imagen 2 de 2
      • The broken air-dry clay craft ornament is now fixed!
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
2 personas más completaron esta guía.
Rhea Matsumoto
Miembro Desde 11/05/24
245 Reputación
1 Guía escrita
Equipo
UC Davis, Team 3-5, Vidal-Chiesa Fall 2024 Miembro de UC Davis, Team 3-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G5
Miembros de 3
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 43
Ultimos 30 días: 181
Todo El Tiempo: 1,944
