Introducción
For months now, I have been trying to find a solution as to why About this Mac will not show my Mac's year and model. I have just now found a solution that has worked on every OS X Version from Lion (10.7) to El Capitan (10.11).
We first must understand how About this Mac shows the year and model.
Check to make sure your serial number is valid.
Using a newer Mac, go to https://checkcoverage.apple.com
Enter the Mac's serial number (the one you are fixing, not the one with the webpage), and a code that Apple makes you put in.
In order to fix this issue, we have to use Keychain.
Open Keychain by searching for it using Spotlight.
If for some reason About this Mac still does not show the year, do not worry. There is one other thing you can do. You can force the Mac to make a new certificate.
To do this, click the "Support" tab in About this Mac.
Then choose "User Manual."
Close all of the windows (including About this Mac).
Now open About this Mac again, and it should show you your Mac's year and model.
Hopefully this will have fixed the issue with your Mac. If for some reason this did not work, drop a comment down below.
