Saltar al contenido principal
How to Fix Scratches on a Steel Watch
Qué necesitas
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: paso 1, imagen 1 de 1
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: paso 2, imagen 1 de 1
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: paso 3, imagen 1 de 3 How to Fix Scratches on a Steel Watch: paso 3, imagen 2 de 3 How to Fix Scratches on a Steel Watch: paso 3, imagen 3 de 3
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Microfiber Cleaning Cloths
    $3.99
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: paso 5, imagen 1 de 1
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: paso 6, imagen 1 de 1
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: paso 7, imagen 1 de 1
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
Linea de Meta
Una persona más ha completado esta guía.
Youssefmo
Miembro Desde 08/31/22
219 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 1,078
