Introducción
Water leaks for the Keurig B70 Brewing System are sometimes caused by an internal disconnection of the water pump and reservoir. Use this guide to open the Keurig and reseat the water pump.
Partes
No se requieren partes.
  1. Before beginning the repair, turn off the brewer and disconnect it from any power source. Move the brewer so that the metal baseplate is easily accessible.
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. Using a spudger, gently pry the metal baseplate from the brewer. Gently set down the baseplate.
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Remove the two silver 4mm Phillips #2 screws that hold the water pump in place. Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
    • Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
  5. Realign the rubber gasket of the water pump to create a tight fit.
    • Realign the rubber gasket of the water pump to create a tight fit.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-2, Maness Winter 2013 Miembro de Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 32
Todo El Tiempo: 20,682
